Temat: MyIDE Driver for SpartaDOS X
I'm not sure how widely used the MyIDE interface is in Europe, but a MyIDE driver for SpartaDOS X is under development:
http://www.atariage.com/forums/topic/16 … de-driver/
http://www.atari8.co.uk/
Updated driver/FDISK will be published on Sunday. The software offers:
- 512 bytes/sector
- 62KB/s DOS reads
- 58KB/s DOS writes
- up to 15 x 32MB partitions
- high compatibility with existing SDX applications
- support for S_VBXE driver (FDISK)
Odp: MyIDE Driver for SpartaDOS X
JEALOUSY.VX at 10 fps:
http://www.youtube.com/watch?v=R36TS0uZuEU
I start test it tommorrow, i think i'm only one who use myide here :)
I think, that there are few users with MyIDE-equipped setup, but it's a shame to admit "I am using MyIDE, because i'm too lame for JŻ/KMK IDE" :)
No offence, this is only joke ;)
Hmm, " i use myide becouse i can't buy  JZ/KMK/Ide"  is better  , i test both platforms and all is good  on one ,bad on second and vice versa.
dely napisał/a:
zaxon napisał/a:
Hmm, " i use myide becouse i can't buy  JZ/KMK/Ide"  is better...
LOL. Sure, it's understandable - largely because MyIDE needs a custom SIO driver and in the past we were obliged to replace the whole Operating System ROM just to make it work.
I have KMK/IDEa (not yet working) as well. Both have their pros and cons. MyIDE is tiny, but I wouldn't want to use it with anything other than the SDX driver. IDEa takes up a lot of desk space, but it does have the cart pass-thru, etc.
Of course, there's added pleasure in using MyIDE with drivers and FDISK I wrote myself. :)
...i test both platforms and all is good  on one ,bad on second and vice versa.
This is a typical scenario. Reliability is so dependant on the Atari timings. However, same is true of unmodded KMK/IDEa...
Ostatnio edytowany przez flashjazzcat (2010-10-13 11:33:48)
Ok, podlaczylem, pobawilem sie, sa pewne niedorobki ale poki co rw test:
dos writing 44761  B/sek
dos reading 48770
dos average 46766
Niezle
Ok, po zmianach i dzieki ciezkiej pracy Flashjazzcata,Candle ,Truba, Drac030, wyklulo sie to:
http://images47.fotosik.pl/359/3c9cee08c0a10ad8m.jpg
http://images40.fotosik.pl/342/76066a12994a0c50m.jpg
http://images41.fotosik.pl/354/f5799812d4db6920m.jpg
W skrocie, interfejs w carcie dzialajacy jako hdd, ostatni rw test to ok 60k zapis i odczyt pod sparta,512 sektory, 16 patrtycji po 32 kilo kazda,  do tego 2 ramcarty  po 128 kilobajtow plus flashowana sparta z zegarem RTC, wszystko w obudowie, plug and play.
Ktos zainteresowany bo puszczam produkcje.
drobne pytanie: ile PLNów trzeba na to wyłożyć ?
okolo 350 zl w wersji na PL
A to będzie zamiast Candle'owego SpeedDrive'a, oprócz, czy jak?
hmm inne rozwiazanie HDD do Atari, kwesatia przyzwyczajen. 95 procent wszystkiego  kmk/idea dziala.
Ostatnio edytowany przez zaxon (2010-10-28 18:22:47)
A kwestia odpalania ATR-ów? Będzie coś takiego możliwe?
to myjdzide rozwiazanie?
nawet jak tak - i mimo tego ze mnie nie stac, wstepnie sie pisze na jedna sztuke
dla mnie jedna sztuke prosze
pozdrawiam
Sniegowy
Poproszę 1 szt.
Co do ATR, nic nie stoi na przeszkodzie w napisaniu softu, ogolnie to jest platforma o sporych mozliwosciach, trzeba tylko chciec. Nie widze sprzetowych problemow, jesli ktos napisze loader uzywajacy obszaru ponad partycjami.Cos nawet na zasadzie microspartados.
to dopisz i mnie, a co tam
http://www.5oft.pl/
Jeśli ktoś przetestuje produkcyjny egzemplarz na paru wybranych rzeczach to i ja wesprę krajowo-zagraniczny joint venture.
ja bym byl wstepnie zainteresowany lzejsza i tansza :-) wersja z 1 ramcartem nawet 8kb i interfejsem myide
ok,  to ja ci zrobie carta a ty dizzy przekonwerujesz na atarke? ok?
My KMK works now, so I needed a reason to use the MyIDE driver:
DOS writing: 59411.3628 B/sek
DOS reading: 71035.3252 B/sek
DOS average: 65223.344 B/sek
(Eight unrolled reads in the MyIDE driver's read loop, and four unrolled writes). :)
Ostatnio edytowany przez flashjazzcat (2010-11-15 15:21:28)
przepraszam, to jest złącze do SD czy IDE?
rczej compact flash wiec ide
JEALOUSY.VX now plays at 11.48 FPS:
PunBB bbcode test
