Odp: 1088XEL Alternative Motherboard Project
Można niby eksportować z ExpressSCH do .bmp a później dopiero kombinować ale to (przynajmniej dla mnie) rzeźba okrutna.
Strony Poprzednia 1 … 4 5 6 7 8 … 13 Następna
Interface myszki działa
PS2 Mouse and Keyboard Plugged In (this particular mouse has dual USB/PS2 protocol)
Upper DB9 ports are from left to right: Sophia Video Out, Joystick 1, Joystick 2
Dalsze rozwinięcie projektu, 1088 XELD
XF551 + SDrive http://atariage.com/forums/topic/265455 … try3761315
Literówka w Pasiu.
Ostatnio edytowany przez pajero (2017-05-14 20:22:28)
autor wypowiedzial sie na temat konkurencyjnego projektu:
"Out of the box the ÉclaireXL has these distinct advantages.
Beautiful HDMI and VGA output built-in
Turbo up to x32 speed without the hassle and incompatibility of some of the other accelerated upgrades
Built-in USB mouse and keyboard allowing the use of modern 'wireless' solutions for either
Built-in SD storage
In fact to tell you the truth if the ÉclaireXL had been announced at the beginning of this year or earlier, there never would have been a 1088XEL, because quite frankly it would have knocked the wind out of my sails to do so."
mam nadzieje nie oslabi to jego zapalu w doprowadzeniu projektu 1088xel do konca.
Please join:
https://www.facebook.com/groups/atarixelclub/
I don't exist on facebook... ;P
Sikor we need ethernet or wifi cart and ataribook.atr!!! :D
I miss BBS times too!
Jeśli chcesz zrobić sobie obudowę .... nie wzoruj się na tym ;)
Nice case! Looks strong. You can take it on Acheron (LV-426). Looks solid. Will survive :D.
... to raczej przetrwa atak przy użyciu car-bomby ;)
From my AtariAge conversation:
ME>>
Hello Michael.
Can you write to Lotharek. Maybe He can produce 1088XEL+VBXE boards. He is doing Rapidus, VBXE, Ultimate 1M, MIST FPGA...
So why not 1088XEL. Maybe just for EU. Best will be to have more manufacturers (US+EU). Price (Postage+Service) will be cheaper for users. Also such strategy was on PC. And was sucessful... One platform more manufacturers...
Matej
Michael/Ataribits.Com>>
Hi Matej,
Not a bad idea. Keep in mind when this project is released anyone can build or produce it, and don't require permission from me to do so. So if you wish to talk to Lotharek yourself about what you are proposing, please proceed.
Michael
BTW guys you have in POLAND superb mini-itx case manufacturer:
http://zaber.com.pl/sentry/#gallery
MADE IN EUROPE...
Or here are CZECH cases:
http://www.emko.cz/produkty/it-skrine/mini-itx
Ostatnio edytowany przez Matej (2017-06-27 22:00:42)
Ciekawa może być kwestia PBI, pytanie tylko czy np. w tandemie z IDEplus objawi się problem z Ultimate 1MB. Pasiu już poprawiał takie komputery.
YOGI is working on m-PBI version of YMari opl3 soundcard for 1088XEL!
Ostatnio edytowany przez Matej (2017-06-29 09:18:07)
Pojawiła się aktualizacja (zbiorcza) schematu i modyfikowana PCB.
Jeszcze nie czas na składanie zamówień....
"No ładne cacko" jak mawiał klasyk.
szkoda tylko, że nie wycięli tej obudowy od razu pod ECI, lub można było wyprowadzić port w całości "z boku".
Wątpie by była używana przez "specjalistów". To projekt dla kowalskiego który ambitnie nie zamyka drogi wyboru innej / większej obudowy.
Wydanie - wrzesień wersja finalna.
Pal problem - rozwiązany
Aktualny schemat: 1088XEL_rev1_1_8-14-2017_schema.pdf
Przypomnijcie mi, czy do tego da się podpiąć IDE+ i włożyć w to Rapidusa? Ktoś próbował?
Wyślij zapytanie do autora projektu, ale nie sądzę by ktokolwiek to sprawdzał.
Jest złącze na IDE+, ale po co?
Na stronie autora jest:
czyli to nie będzie znane nam IDE+ tylko przejściówka do włożenia przejściówki dla kart CF
Rapidus
tu, zapowiedzi: http://atariage.com/forums/topic/261147 … try3722881
No ale nie doczytałem, czy testowane
IMHO marneszanse - bo to rapidusa trza dostrajać do płyty (jeszcze).
Ostatnio edytowany przez pajero (2017-08-31 18:27:13)
No, przepraszam, jak to "po co?" Po to, że IDE+ jest sprawdzonym rozwiązaniem.
Jedyną (ale bardzo ważną) przewagą takiej płyty nad czymkolwiek innym może być to, że można jej zaaplikować rozszerzenia sprzętowe od prawdziwego Atari, i że one będą nadal działać. IDE+ nawet nie jest rozszerzeniem, jest po prostu urządzeniem peryferyjnym zaprojektowanym pod złącza I/O Atari.
Chcesz zastąpić to złączem do karty CF? To się zrewanżuję pytaniem: PO CO? Karta CF (pomijając to, że jest standardem odchodzącym w przeszłość) jest *tylko* pewnym zasobnikiem na dane, konkretnego typu, który to typ zdecydowanie odchodzi w przeszłość. Lepiej (chyba?) jest zostawić urządzeniu PBI swobodę w decydowaniu, jaki nośnik chce obsługiwać, co?
Czyli co konkretnie, bo zasadniczo nic z tego nie rozumiem.
[ Wygenerowano w 0.132 sekund, wykonano 14 zapytań ]
