Temat: Coś dla grafików (pewnie bardziej Atari 16/32 bit) - COMPO
Compo na ZX Spectrum Evolution, ale format jest dostępny z PC - BMP, 320x200, 16 kolorów z palety 64 kolory (plik z paletą i przykładowymi obrazkami dostępny tutaj: http://yerzmyey.republika.pl/gfxcompo2014ivp.rar).
********Deadline - 16 sierpnia / 16 August 2014********
_________________________________________________________________
While this year edition of International Vodka Party we would like to organize a graphic compo especially for ZX Spectrum Evolution (320x200 in 16 colours out of 64-colours palette, each pixel can have its own colour).
You don't have to be an owner of the machine (nor the compatible - ATM Spectrum model), the format is simple: ***BMP*** file, 320x200 resolution, 16 colours on the screen (out of the 64-colours palette of ZX Spectrum Evolution).
You can recognize easily that the final file format is OK: the BMP file will be exactly 32118 bytes long.
This gfx-mode is available for Spectrum world since 1991, but it wasn't used very often. Which now changes 'cause Eva is the only reasonable choice if one wanna get a new ZX model.
2 pictures per author allowed.
Unlike the converts – converted pictures are NOT allowed at all.
We provide You a "zx_eva_palette.pal" file that You can load into Your favourite PC (and Mac possibly) gfx-editor and draw the compo picture(s).
Example of loading the palette file into PaintShop:
COLORS / LOAD PALETTE and... yes, "OPEN" file. ;) Still, You can use only 16 colours out of those 64 ones.
Check out the example BMP files, too.
Send Your works to yerzmyey AT poczta.onet.pl
Sending 2 versions - signed and unsigned - might be a reasonable choice.
Note: if You didn't get any confirmation from me, that means I DIDN'T GET YOUR FILE!!!
Note 2: We consider also making an on-line voting for everybody, after the party.
Note 3: You can send as well the TRD/SCL 256x192 RGB format pictures (called also "8color" or 3"color" sometimes) but remember You can use there only 8 colours of standard ZX Spectrum palette, and such pictures will compete with Eva's pictures, so it might not be a "fair fight" (although the RGB gfx-mode is stable on ZX Evolution - it doesn't blink).
Regards,
Yerzmyey/HOOY-PROGRAM^AY-RIDERS
