flashjazzcat napisał/a:Found the bug. An extra (non-existent) entry from the table of LBA partition table sector numbers was being grabbed from the array when the last partition was at the end of a sector of the APT chain. Since the bug resulted in MBR corruption, it seemed a good idea to add debugging code which triggered a breakpoint if any attempt was made to write sector 0 when laying out the APT. The breakpoint was immediately triggered with 78 partitions...
Please try the version attached and let me know if it passes Pin's most extreme stress-tests. :)
 17 partitions created
Reading MBR from example_disk.img starting at sector 0 (0) [0]
parent: 0 partition data: 446-462, type: FAT32, LBA
parent: 0 partition data: 462-478, type: APT, Atari Partition Table
Reading 512 bytes from sector 0x40003F (4194367) [0x80007e00 (2147515904)]
Found APT partition at sector 0x40003F (4194367)
Reading 512 bytes from sector 0x400690 (4195984) [0x800d2000 (2148343808)]
Found APT partition at sector 0x400690 (4195984)
55AA
b'APT' 0 32 0x400690 0x0
mapping_slots:
partitions:
{0:             67,  0,   0x400041 (     4194369 bytes),       0x64 (         100 bytes),  0, 64
, 1:             67,  0,   0x4000a6 (     4194470 bytes),       0x64 (         100 bytes),  0, 64
, 2:            67,  0,   0x40010b (     4194571 bytes),       0x64 (         100 bytes),  0, 64
, 3:            67,  0,   0x400170 (     4194672 bytes),       0x64 (         100 bytes),  0, 64
, 4:            67,  0,   0x4001d5 (     4194773 bytes),       0x64 (         100 bytes),  0, 64
, 5:            67,  0,   0x40023a (     4194874 bytes),       0x64 (         100 bytes),  0, 64
, 6:            67,  0,   0x40029f (     4194975 bytes),       0x64 (         100 bytes),  0, 64
, 7:            67,  0,   0x400304 (     4195076 bytes),       0x64 (         100 bytes),  0, 64
, 8:            67,  0,   0x400369 (     4195177 bytes),       0x64 (         100 bytes),  0, 64
, 9:            67,  0,   0x4003ce (     4195278 bytes),       0x64 (         100 bytes),  0, 64
, 10:           67,  0,   0x400433 (     4195379 bytes),       0x64 (         100 bytes),  0, 64
, 11:           67,  0,   0x400498 (     4195480 bytes),       0x64 (         100 bytes),  0, 64
, 12:           67,  0,   0x4004fd (     4195581 bytes),       0x64 (         100 bytes),  0, 64
, 13:           67,  0,   0x400562 (     4195682 bytes),       0x64 (         100 bytes),  0, 64
, 14:           67,  0,   0x4005c7 (     4195783 bytes),       0x64 (         100 bytes),  0, 64
, 15:           67,  0,   0x40062c (     4195884 bytes),       0x64 (         100 bytes),  0, 64
b'APT' 0 2 0x0 0x40003f
mapping_slots:
partitions:
{1:             67,  0,   0x400692 (     4195986 bytes),       0x64 (         100 bytes),  0, 64
one deleted and looks good
55AA
b'APT' 0 32 0x0 0x0
mapping_slots:
partitions:
