Temat: Log Apache
Od jakiegos czasu zauwazylem w moich logach dziwne odwolania (log ponizej). W sumie normalnie by mnie nic nie dziwilo, ale dziwi mnie ich cyklicznosci i to ze odwolanie jest tylko do obiektu favicon.ico. Zaczelo sie to 16 Pazdzienika i tak ciagnie sie caly czas
Czy to nie jest przypadkiem taka sytuacja jak kto doda strone to bookmarkow i w chwili rozwijania menu jest zczytywana icona strony ??
Czy ktos z Was spotkal sie juz z czyms takim ???
66.156.97.58 - - [18/Oct/2008:06:27:03 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:06:42:04 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:06:57:00 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:07:12:02 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:07:26:59 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:07:41:59 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:07:56:57 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:08:11:59 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:08:27:04 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:08:42:03 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:08:57:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:09:11:58 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:09:26:57 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:09:41:59 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:09:57:03 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:10:12:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:10:27:00 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:10:41:59 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:10:56:57 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:11:12:00 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:11:27:00 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:11:42:03 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:11:57:03 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:12:12:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:12:27:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:12:42:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:12:57:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:13:11:58 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:13:27:01 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:13:41:58 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
66.156.97.58 - - [18/Oct/2008:13:56:56 -0400] "GET /favicon.ico HTTP/1.0" 200 1334 "-" "CFNetwork/330.4"
Ostatnio edytowany przez Monsoft (2008-10-30 03:48:17)
Odp: Log Apache
Wyglada na jakiegos bot-a http://www.botsvsbrowsers.com/details/206620/index.html
Odp: Log Apache
wyblokuj pukacza na fw
Odp: Log Apache
Znalazlem ta sama strone. Ale na innej znalazlem ze to tez wystepuje wtedy jak ktos doda strone do bookmarkow.
Oczywiscie dodatem stosowna linijke w IPFW.
Odp: Log Apache
firefox domyslnie pobiera favicon dla kazdej strony ktora otwiera nawet jesli nie jest zdefiniowana w
samym pliku. Moze to cos tez tak robi. Ja tam bym sie nie przejmowal.
Odp: Log Apache
mialem kiedys taki problem... oczywiscie te zapytania o plik generuja boty, natomiast robily to dlatego, ze cos byla zepsuta konfiguracja.. i teraz nie pamietam czy vhostow apache czy konfiguracji dns (bind)
Odp: Log Apache
W vhostach nie mozna za duzo popsuc. Dziwi mnie to iz to jest tylko z jednego ip, a co jakis czas z tego IP ktos otwiera uzywajac Safari normalnie moja strona.
