Temat: help me with BASIC :)
i have problem with stick 14 - it's doesnt work.. it's a simple PMG.. move to left, right, bottom is OK, but TOP is broke..?
LOAD "D1:HRA.BAS"
RUN
enter your name, return.
http://podstromami.com/hra.atr
Ostatnio edytowany przez w1k (2009-03-24 20:37:33)
ATARI 800XE with u1mb, stereo, covox, ramdisk hell led, ultra video 1.0 XE.
SIO2SD, SIDE3, sio2usb, sio splitter, dragon cart, lantronix mss-100, fujinet (lotharek), rverter, A8PicoCart, BT-100, XC12 (T2000), XC12 (SUPER TURBO, TURBO D), both with internal speakers
https://www.youtube.com/@w1katari/
Odp: help me with BASIC :)
Hi!
At line 280 you have:
280 IF STICK(0)=14 THEN RKT1H=RKT1H-1:DIR=NAHORU:GOTO 340
if you change the DIR=HAHORU to DIR1=NAHORU it will be work:
280 IF STICK(0)=14 THEN RKT1H=RKT1H-1:DIR1=NAHORU:GOTO 340
greetings
Seban
great.. i'm silly.. :) thanks
