Temat: MADS .array usage
Hello there,
I have a problem using .array statement in MADS assembler. I am still learning assembly language and I hope someone will help me. In particular, in my case, how can I show a string on the screen, which is declared as an array? I know I am doing something wrong using dta statement, which shows string address instead of an actual string. The solution will come handy when declaring new strings with the usage of the same declared array, eliminating the need for declaring new labels for any new strings.
Greetings to all Atarians,
Gury
org $3200
.array str1 10 .byte
[0]="Atari"
.enda
Main
jsr printf
dta c'%',$9b,0
dta a(str1)
jmp *
.link 'c:\atari\utils\mads\examples\libraries\stdio\lib\printf.obx'
run Main
Odp: MADS .array usage
printf
#    - string
@    - ATARI FLOAT
%    - WORD
' '              - ATASCII
" "             - INTERNAL
new mads accept .array without declared size
    org $2000
.array str1 .byte
    [0]='Atari',$9b
.enda
Main
    jsr printf
    dta c'#',$9b,0
    dta a(str1)
    jmp *
.link 'stdio\printf.obx'
    run main
Tebe, thank you.
