Odp: Sio2SD firmware 3.1 RC_2
Test pokazuje, że formatowanie kończy się powodzeniem na Sio2SD. Ale nie kończy się dla Atari, przynajmniej aż do end Timeoutu. Czyli zapomniano wysłać STATUS ok.
hm, i try re-flash with atmel cable, but i wait for USB-LPT..
i using this cable from flash sio2sd
http://www.atari.turiecfoto.sk/albums/a … G_0598.jpg
i have new MB on pc without LPT..
can i use this cable?
http://www.softcom.sk/eshop/delock-konv … 05272.html
I don't think so...
Bu I can recommend yu to buy a cheap chinese USBASP version.
Fx:
http://www.ebay.co.uk/itm/New-USB-51-AV … 3ccb7ad641
This LPT-USB converter probably will not work correctly.
There are special LPT-USB converters for programming devices, and they are not cheap.
This USBASP could help you. But seller is not sending to Slovakia - see exclusions list, probably post offices not collaborates.
Try to find it locally. Or another seller. And wait for delivery, 3-4 weeks.
Better, if you have more cash: http://www.ebay.co.uk/sch/i.html?_nkw=g … programmer
Ostatnio edytowany przez lemiel (2013-03-18 13:59:12)
i buy LPT for PC.. - 7EUROS
not working..
video:
https://www.youtube.com/watch?v=GjQHXXRH8oY
windows 8 64bit
Let me guess.
Does this CARD support parralel port at STANDARD adresses ?
where i can find that?
more info:
http://www.alza.sk/axago-pcia-p1-d283795.htm
Podpora Re-Map IO Address – nastavení adresy LPT portu (tato funkce je podporována pouze v DOS)
Chceck drivers settings.
I/o Dc00-dc07
I/o D880-d887
Ostatnio edytowany przez w1k (2013-03-22 12:44:09)
http://en.wikipedia.org/wiki/Parallel_port#Interfaces
Most PC-compatible systems in the 1980s and 1990s had one to three ports, with communication interfaces defined like this:
LPT1: I/O port 0x3BC, IRQ 7 (usually in monochrome graphics adapters)
LPT2: I/O port 0x378, IRQ 7 (dedicated IO cards or using a controller built into the mainboard)
LPT3: I/O port 0x278, IRQ 5 (dedicated IO cards or using a controller built into the mainboard)
If no printer port is present at 0x3BC, the second port in the row (0x378) becomes LPT1 and 0x278 becomes LPT2. Sometimes, printer ports are jumpered to share an interrupt despite having their own IO addresses (i.e. only one can be used interrupt-driven at a time). In some cases, the BIOS supports a fourth printer port as well, but the base address for it differs significantly between vendors. Since a fourth printer port is conflictive with other features on PS/2 machines, it typically requires special drivers in most environments.
so.. can i change it or..? move card to trash?:)
Or better use another programmer sw.
Try avrdude.
AFAIR it allows you to give a specific IO adress instead of LPT1.
-- edit:
Its explained fx. here:
http://arduino.cc/forum/index.php?topic=48737.0
Ostatnio edytowany przez willy (2013-03-22 13:07:16)
i cant setup it.. :/
milion of options..
What about gui for avrdude ?
http://sourceforge.net/projects/avrdude-gui/
execution of command loaddrv status failed
f**k of that..
i go try install windows xp..
or windows 3.1 maybe better..
vrrrrr
Ostatnio edytowany przez w1k (2013-03-22 13:32:13)
Before using AVRDUDE, the giveio.sys driver must be loaded. The accompanying
command-line program, loaddrv.exe, can do just that.
Google is your friend.
http://nongnu.uib.no//avrdude/avrdude-doc-5.4.pdf page 24
maybe in next life.. im trying flash it 5-6 hours? i bored reading 500 manual papers, with my poor english..
i go try win xp 32bit..
but thanks for replies :)
windows 7..
LOL
now when cable is in sio2sd, sio2sd boots normal.. no activity
today received USBasp
bude nove RC?
Fakt, jest parę niedociągnięć. Ale Acid nie odpowiada na e-maile od roku... tylko on ma źródła. Mogę w smutku pogrążony napisać - że pewnie projekt umarł... albo sam napiszę wszytko od nowa na większy procek.
Błędy:
- ATR nie pełnej wielkości (ostatni sektor różny od 128/256b) = zwis wsadu
- Nie kończy formatowania ATRów = czeka aż do Timeout
Niedociągnięcia:
- dostęp do FAT tylko dla jednego pliku jednocześnie (nie mylić z D1-D15 i V0-V99) - rozkazy: Cmd>$20
Zawsze pozostaje jeszcze Reverse Engineering - ale prościej byłoby gdyby autor uwolnił źródła.
A większy procek się zmieści w te same płytki?
[ Wygenerowano w 0.096 sekund, wykonano 15 zapytań ]
