Hi everyone,
Boogie nights works, Joyride works, Overmind works, acid800 100% pass.
Saturday demo sounds the same to me. Tell me more what you think is wrong.
Known problems with: Turmoil, Spider City, AD6502 Fractal part.
I've checked Numen again and it now crashes:-( This ran ok for over a year before. I need to check if builds prior to 20141016 work - there was a CPU upgrade then.
edit: Found the Numen regression. I was trying to fix 'double dot clock mode' (80 column gr 0) in Novmber and broke something in Antic. Reverted it and building the cores.
Acid800 was my main testcase but it does not test everything. More small apps or even tests like Speedmaza needed (love that game!)
There are some problems are with the drive emulation (sdrive based) and custom loaders. Some only work with sio2pc (or real 1050), which so far can not be connected to the mist (yet...). On the latest core one can set the minimum pokey divisor of the sdrive from 6 to default (0x28) which fixes some programs.
Still some way from perfection but its already pretty close.
Sorry for using English. I only know English and some French!
Ostatnio edytowany przez foft (2015-04-08 07:01:17)
