i very very please.. i need sio2pc cable to my atari800xe, because my xc12 is broke.. but i don't have money in this time, i wait for payment (next month :( )..
i can change sio2pc with
-sony ericsson k800 (unlocked, dvd with 2000 games, firmware, flash software, etc)
some photos - www.podstromami.com
-and original game c&c generals (4 cds)
pleaaaaase
https://github.com/viktorcech/
"tak mnie wychowano, żeby z butów mi nie wystawało siano.. no a za te siano kupię sobie buty, lubię dobre skoki jak mój ziomo Banot"
2 Ostatnio edytowany przez maw (2009-03-24 23:43:18)
Hi, on atarionline: MP3 player as datareader look at this forum too as "mp3 player".
___
Press play on tape...
w1k: can't help now, I have one working unit and one "rest in pieces".
But try asking at http://forum.atari.sk
forum.atari is BRAK, new registration doesn't work.. that forum are no technical support .. :(
Cant you just do it by yourself? SIO cable/plug is the most important/expensive part of this device.
Here is the schematic:
http://atariki.krap.pl/index.php/SIO2PC
(i suggest max232 version)
uff. i know about all schematics about sio2pc, but.. :(
i'll look into my junkbox and see what can be done.
ok, thank you :)
do you have a sio plug?
yes, i have.. from xc 12
I hope if you get the device you will be able to connect the sio plug?
yes, that's no problem for me.. my dad can help me :)
xan, can you help me?
Unfortunately I have no parts for the device. I am also unable to go to the local electornic store to buy some (they are closing it before I leave my office) so I have to order these parts via internet but this will take few days. Are you still interested then?
no problem (if is no problem for you), i want.. thank you :)
Parts are on the way... Probably you won't get a fancy custom PCB board, I will use a stripboard due to lack of time but it should work ;)
that is no problem, thank you :)
Ok, I have the parts. I'll try to solder it before weekend.
ok :)
