hello,
i use sio2pc to simulate diskdrive from my atari (800xe, 64kb).. but 80% of files doesnt work.. i use APE..
loading, loading and than freeze..
mercenary is OK
BASIX is OK
ROBBO is ok
but some demos (1kb, 64kb) doesnt work.. games too
THE 800XL Atari zapowiada The 800XL z pełnowymiarową klawiaturą, HDMI, portem na cartridge i 25 grami.
CAS2Audio 1.0.9 Nowa wersja aplikacji odtwarzającej pliki kasetowe na Androidzie z architekturą MVVM.
HighWire 0.5.0 Beta 4 Przeglądarka internetowa dla Atari z obsługą 68000, ColdFire oraz wieloma nowymi funkcjami.
Gearlynx 1.2.34 Wydano nową wersję 1.2.34 emulatora Atari Lynx z licznymi usprawnieniami i nowymi funkcjami.
Port gry Toadies na Atari STE Toadies, turowy klon Worms z Amigi, trafia na Atari STe dzięki projektowi KtZ i AGT.
atari.area forum » Sprzęt - 8bit » problem with sio2pc
hello,
mercenary is OK
BASIX is OK
ROBBO is ok
Hi w1k.
Some productions use memory in very strange way (e.g. they don't like DOS'es etc.).
Do you try to load them from PC-Mirror or from ATR's? PC-Mirror sometimes works weird, and some ATR require BASIC to be disabled.
And many demos need extended memory (64k of so-called XMS or more) - maybe this is main problem. Maybe give some non-working titles as examples.
thank you, miker
i simulated my atari with emulator - enabled basic, 64kbram, but everything is ok.. i try load exe, com from atr and bootable atr too.. 80% not work.. classic games - saper, draconus.. :(
can i turn off basic on my atari? yes, it's correct.. in emulator (64kb, basic on) programs doesnt work too.. sio2pc is ok.. but that basic, wrr
hold OPTION key when Atari is turned on
w1k dont say that you got sio2pc by yourself!?!
Zaxon, no no, one electrotechnian made it for me.. but i'm interested for your sio2pc :)
Zaxon haven't written any post here yet :) But Xan - yes, of course :)
w1k, you dont need this cable anymore. I will give it to someone in Poland.
oo, ja jestem zainteresowany takim kablem :)
xan - ile chcesz za niego?
pamiętaj, że jest bez wtyczki sio więc trzeba ją sobie samemu zorganizować.
Wygenerowano w 0.030 sekund, wykonano 52 zapytań
