XLent napisał/a:Hi
Here you have several versions of ready to use:
 Hi, XLent, nice to meet you!, excellent, runs perfect all these versions!!! problem solved!
Monsoft napisał/a:As Fox and Jellonek mentioned to be able to save (I think load as well) song in CMC it must be run from DOS. If I remember well original CMC came with DOS 2.5  but I think most people use it with DOS 6.4 or MyDOS.
Actually there was CMC 2.0+ and CMC 2.0s+. CMC 2.0s+ allow you to play song using 2 POKEYs. If I remember well (we - Hugo and I - did this stereo enhanced version 14 years ago) using button START,SELECT, OPTION you can choose which channel will be played on which one Pokey (lewy - left, prawy - right, dwa - both, NIE - turn off channel). In most hardware stereo upgrades old Pokey is connected as left speaker and new one as right.
If your Atari have only one Pokey, this version on CMC is not usable for you.
 Hi, Monsoft, nice to meet you!
(lewy - left, prawy - right, dwa - both, NIE - turn off channel)  this is very good for playing live and mute channels!, and switch the polyphony on channel 1 of some instruments that are specifically for that channel 1.
Do you know the keyboard commands to set the basstables and a volume-table on the CMC RZoG version? looks promising!!!
Someone has a link to download the stereo version SCMC ver.7 ? 1998 Datri Software???
So thanks friends for the good support!!!!  :)
						www.e-bot.net
