26
ok, when i CONNECT diode to 7 PIN - than be light when i use extend ram (ramdisk)? .. when i use basic 64kb, it's no light? what about is 7 pin? thank you very much, tommorow i tell dad.. he is sceptic about this connect (7 pin).. he says that it does not matter where on PIN the LED is connect..
I am confused :(
ATARI 800XE - u1mb, pokeymax4, ramdisk hell led, ultra video 1.0 XE.
SIO2SD, SIDE3, sio2usb, sio splitter, dragon cart, lantronix mss-100, fujinet (lotharek), rverter, A8PicoCart, a8 pico sio, BT-100, XC12 (T2000), XC12 (SUPER TURBO, TURBO D), both with internal speakers. ATARI 800XE - 2xos (XL OS, Q-MEG), ATARI 800XE stock
my youtube channel
27 Ostatnio edytowany przez BartoszP (2009-12-29 23:32:46)
If low state of PIA pin 14 means EXTRAM activity then double NAND gates used as double NOT  gates give the same state as PIA pin 14 has.
So if diode is reversed then it should be ON when EXTRAM is accessed and OFF when PB4 (pin 14) is high. So it should work as expected.
W1k - tell Dad that everything works better if it is properly connected to power source :)
28
look at this video:
http://www.youtube.com/watch?v=fBe-3cue6Qc
my youtube channel
29
ładny dymek - czyżby diódka przyjęła na siebie pełne 5 volt ? gdzie był rezystor i jaki (4.7k, 2.2k, inny ?) ?
___
Press play on tape...
30
I think that smoke is not from the diode. It comes from connection track.
Looking at the picture I see that green cable is power and red is ground.
Orange is PB14 so it is not properly connected. It is input 3A for gate 3 (see my previous link)
The second input comes from output 4Y from gate 4..... please verify your conections as I can not see more...
Remove this masterpiece from ATARI...connect it to battery and check the logic outside your computer.
31
interesting is a first smoke, two days ago - from 14 pin in PIA..(photo 3) now smoke connection track..
http://podstromami.com/i/a.jpg
http://podstromami.com/i/b.jpg
http://podstromami.com/i/c.jpg
http://podstromami.com/i/d.jpg
my youtube channel
32 Ostatnio edytowany przez w1k (2009-12-30 12:37:36)
my dad says:
i cant do anything, because 14pin is OFF (fired, broken)
my youtube channel
33 Ostatnio edytowany przez maw (2009-12-30 13:14:00)
PIA is dead... Wik, do you know Jer's page - dereatari ? Probably not only the leg 14 of PIA will be smoked...
___
34
PIA is ok.. maybe 14 pin is dead.. yes, dad have that schemes (printed)
my youtube channel
35
ok, not dead - only zombie ;-)
___
36
now it's works fine :)
http://www.youtube.com/watch?v=afUbkARunWU
http://www.youtube.com/watch?v=GpVUGgQum4o
my youtube channel
37
Ramdisk activity checker - one transistor!
http://blog.3b2.sk/igi/post/Tipy-a-trik ... ricks.aspx
38 Ostatnio edytowany przez Jacques (2010-05-23 18:40:05)
Geez... Why do you complicate it so much? :) LED diode, 510 Ohm resistor and 74LS04 (NOT gates) placed on another existing LS on the board makes it work :)
39
why to use IC when single Q suffice?
first version of simplestereo (first ever made) was using single transistor for all of address decoding circuitry
i don't see a point of using integrated circuits here, so i belive its far more elegant and simple than what you belive is "simplier"
40 Ostatnio edytowany przez zaxon (2010-05-24 15:09:19)
Candle , http://www.onsemi.com/pub_link/Collater ... SZ00-D.PDF  it is integrated circut? Is. LOL
41
Odkopuję temat.
Czy dobrze myślę: taka kontrolka jest bez sensu bo będzie mrugać nie tylko przy ramdysku ale także np. przy wykonywaniu poleceń np. Sparty ?
42 Ostatnio edytowany przez Pin (2016-02-26 14:36:04)
w trybie Banked, np. odczytanie DIR z CP będzie powodować "mruganie" w czasie odczytu katalogu. Niemniej jednak nie widzę w tym uciążliwości a faktem jest użycie przez dos rozszerzonej pamięci w tym właśnie momencie ;)
43
Pin masz to coś zamontowane u siebie ?  Co się będzie działo przy włączonej TDLine ?
44
Chyba nikt nie ma, bo jest to raczej bezużyteczny wodotrysk, a przynajmniej ja dla niego zastosowania nie widzę, chyba że ktoś montuje Atari w Passacie ;)
45
Montują i nawet chwalą się na youtube. Zaciekawiło mnie to bo pamiętam, że jak kiedyś w szkole pisałem programiki na zajęcia pod Mydosem to brakowało mi czegoś takiego. A że mam rozłożoną XLkę do montażu U1Mb to z ciekawości wsadziłbym ten tranzystor z diodą i popatrzył na tańce nowego ramu :-)
@skrzyp - można zakupić Twoje kartki dźwiękowe ?
46
Co kupić? :o
47
Oj ! Przepraszam Cię bardzo skrzypiący bracie. Pomyliłem Ciebie Z Sonari. Jeszcze raz sorki. Zmylił mnie Twój podpis CM8833-I.
Chyba, że nie.
48
Ujmę to tak.
http://www.mooreadamsoncraig.co.uk/wp/wp-content/uploads/2012/10/head-in-hands.jpg
49 Ostatnio edytowany przez Yansen (2016-02-26 21:00:26)
Ok, ogarnąłem.
Oby powyższy obrazek nigdy nie kojarzył mi się z przedmówcą :-)
50 Ostatnio edytowany przez Pin (2016-02-26 22:10:22)
@Skrzyp - pier*** jak poparzony. Led od ext ram to zajebista rzecz. Od razu wiesz, czy dane demo, muzyka czy program ogólnie używa dodatkowej pamięci.
@Yansen - przy TD line, mogę zaraz sprawdzić choć - TD Line to problematyczny przeżytek, którego mam nadzieje Draco pozbędzie się czym szybciej, tym lepiej. TD bezpośrednio odwołuje się do pamięci ekranu, więc idea CON: leży tutaj na całej linii.
Tak czy inaczej, być może nowe SC będzie miało zegarek (i nie tylko, zmian cała masa). Wyjdzie jeszcze w praniu ;)
Co do LED ext portB, to ja to mam podłączone tak:
masa, + z 14 pin PIA przez rezystor... eee - nie znam się ale miernik pokazuje 0.7kohm na odpiętym ledzie.
