1 Ostatnio edytowany przez YERZMYEY/HOOY-PROGRAM (2022-05-11 07:27:06)
Nie wiem, czy już było.
Było już...?
https://www.cbmstuff.com/index.php?rout … duct_id=60
https://www.cbmstuff.com/image/cache/catalog/WiModem/wimodem232_OLED_2-1600x1200.jpg
______________________
The WiModem232 is an internet modem for any computer with a RS-232 interface port that emulates a standard Hayes compatible modem. Just plug the WiModem232 into the "serial" port and connect to BBS's all over the world or run a BBS of your own!
The WiModem232 requires access to your local router and supports easy WiFi setup, including WPS one-button setup!
Firmware updates are done using a simple command that fetches the latest firmware from the CBMSTUFF.COM server and updates the WiModem232 - all without ever having to remove the WiModem232 from your computer!
The WiModem232 hardware supports 300 baud to 115200 baud. Note: the terminal software you are using determines the maximum baud rate.
The WiModem232 requires external 5v power. Connect any 5v source (PC, phone charger, etc.) using a cable having a Mini-B type USB connector.
The WiModem232 V2 controls ALL of the standard RS-232 lines: Rx/Tx, RTS/CTS, DTR/DSR, and DCD all at the same time. This means that you can use the WiModem232 to run a BBS!
A DB25 to DB9 or RS-232 gender changer may be required for your particular computer. These are available separately. The WiModem232 uses a DB25 female connector (plugging into a DB25 male port).
______________________________
Works with the following computers:
Atari ST (all models)
Commodore Amiga (all models, A1000 requires gender changer)
IBM PC (all models wtih DB9 or DB25 - may require converter or gender changer)
Apple 8 bit (all models, requires proper cable)
Geneve
Tandy 100/102
Atari 400, 800, 800XL
Colleco Adam
TI99-4/A
BBC Micro
RS-232 dumb terminals
...and many others!
Ha. Ciekawe.
Nie było, a wygląda na fajną zabawkę. :)
fajne,
Nie zebym sie wczytywal w opis, ale mi to wyglada na urzadzenie oparte na idei uzycia esp8266
Tyle że do Atari 16bit szybsze będzie NetUSBee, a w przypadku ST będzie ono o wiele szybsze (bo w ST RS-232 wyciąga tylko 19200).
6 Ostatnio edytowany przez Cyprian (2022-05-11 16:03:14)
Adam Klobukowski napisał/a:
wyciąga troszkę więcej (307 Kbps ) ale nikt tego chyba jeszcze nie używał:
https://atariage.com/forums/topic/25510 … nt-4751894
widziałem jakieś mody i istnieje możliwość podmiany scalaków na jakieś lepsze i można wyciągnąć więcej, ale nie pamiętam szczegółów. Jest to chyba opisane w hsmodzie..
[www] https://nokturnal.pl
Cyprian napisał/a:
Papier wszystko przyjmie, uwierzę jak zobaczę :P
saulot napisał/a:
Mody są, ale są to... mody :P
ehhhh jak nie było - wydaje mi się że kiedyś pisałem na tym forum że zamierzam kupić itd.
Były głosy że tylko BBSy i że bez sensu :-)
Mam to urządzenie i jest super - łączyłem się z BBSami i przesyłałem pliki na Atari ST, Atari Portfolio, Apple IIc, starych PC, Amiga itd. - działa super.
Dla mnie to mega fun połączyć bardzo starą maszynę ze światem online :-)
Zabawa ale bardzo satysfakcjonująca :-)
