26
No to mała optymalizacja - linia 114 out, mod 101, dodane popierdółki do moturu...
9 TRAP 31782
10 ? CHR$(125);"LOAD ";CHR$(34);"C:";CHR$(34)
20 SOUND 3,52,14,8:FOR I=0 TO 2000:NEXT I
21 P=53760:SOUND 0,5,14,8:SOUND 1,7,14,8:POKE P+15,43:FOR I=0 TO 255:POKE P+13,PEEK(40960+I):NEXT I
22 SOUND 0,0,0,0:SOUND 1,0,0,0:SOUND 3,0,0,0
23 MOTUR=0
30 ? :FOR B=0 TO 4:READ A,C:? CHR$(A);CHR$(253):FOR D=0 TO C:NEXT D:NEXT B:DATA 69,100,82,100,82,0,79,0,82,0
40 DIM A$(1):RESTORE 40:? "READY":FOR I=0 TO 2:READ A$:? A$;:FOR C=0 TO 255:NEXT C:NEXT I:DATA R,U,N
50 ? :? "DeCRUSHing":FOR I=0 TO 255:POKE 53274,PEEK(53770):NEXT I:? CHR$(125)
100 DIM C$(1)
101 ? CHR$(125):? "?????":? "|* *|":? "?????":? "CASSATE OPERATING SYSTEM 1.2.3":? "2023 BC (C) BY PACT"
102 ? :? "YOU'RE SITTING ON STOOL NEAR THE TABLE WITH ATARI 400 AND TAPE RECORDER ON."
103 ? "THROUGH THE WINDOW YOU CAN SEE REAL WORLD. BEAUTIFUL WORLD..."
104 ? "NOW YOU CAN DO:"
105 ? :? "STATUS MOTORU: ";:IF MOTUR=1 THEN PRINT "ON"
106 IF MOTUR=0 THEN ? "OF"
107 ? :? "A.MOTOR ON":? "B.MOTOR OFF":? "C.LOAD PROGRAM":? "D.RUN PROGRAM":? "E.MAKE DEMO":? "X.EXIT"
108 ? :? "WHAT NOW";:INPUT C$
109 C=0:IF C$<>"" THEN C=ASC(C$)-64
110 IF C=24 THEN GOSUB 20000
111 ON C GOSUB 10000,12000,14000,16000,18000:GOTO 101
10000 REM MOTOR ON
10005 IF MOTUR=0 THEN GOSUB 21000:RETURN
10010 PRINT "ERROR: MOTUR JUZ JEST ON";CHR$(253);"!!!"
10015 GOSUB 31421
11000 RETURN
12000 REM MOTOR OFF
12005 IF MOTUR=1 THEN MOTUR=0:SOUND 0,0,0,0:POKE 54018,60:RETURN
12010 PRINT "ERROR: MOTUR JUZ JEST OF";CHR$(253);"!!!"
12015 GOSUB 31421
13000 RETURN
14000 REM LOAD PROGRAM
15000 RETURN
16000 REM RUN PROGRAM
17000 RETURN
18000 REM MAKE DEMO
19000 RETURN
20000 REM EXIT
20001 GRAPHICS 2+16
20002 POSITION 1,4:? #6;"   IT IS NOW SAFE"
20003 ? #6;"     TO TURN OFF"
20004 ? #6;"    YOUR COMPUTER"
20005 GOTO 20005
21000 MOTUR=1:SOUND 0,10,0,1:RESTORE 25000:FOR I=0 TO 3:FOR J=0 TO 4
21001     READ A$:? A$;:NEXT J
21002   ? :NEXT I
21003 FOR I=1 TO 1000:NEXT I:RETURN
25000 DATA v, , ,_,.
25001 DATA ?,?,?,?,
25003 DATA ?, , , ,?
31421 FOR OPUZNIENIE=1 TO 1000:NEXT OPUZNIENIE:RETURN
31782 ? "ERROR: WYKRYTO ZLE NACISNIECIE";CHR$(253);"!":TRAP 31782
31783 GOSUB 31421:GOTO 101
32760 REM ---
32761 REM PRIMA APRILIS COMPO 2023 TAPE RECORDER
32762 REM BY PRIMA APRILIS COMPO TEAM:
32763 REM MONO, SIKOR, MQ, LIZARD, MGR INZ. RAFAL, DELY
pa2023.lst 2.23 kb, nikt jeszcze nie pobierał tego pliku.
A kto wygra konkurs skoro jest tylko jedna praca?
28
ostatni który dołoży kod
Atari V4SA / Lynx I / Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM124 / SC1435
Jak w licytacji:-) No to trzeba się zasadzić niczym snajper:-) Nie wiem czy silnik forum da radę na taki masowy atak:-)
30
każdy ;)
Dodany blok ładowania:
9 TRAP 31782
23 MOTUR=0
100 DIM C$(1)
10000 REM MOTOR ON
10015 GOSUB 31421
11000 RETURN
12000 REM MOTOR OFF
12015 GOSUB 31421
13000 RETURN
14001 ? "Loading:";:FOR I=0 TO 50:? ".";:FOR J=0 TO 50:SOUND 0,10,10,10:NEXT J:SOUND 0,0,0,0:NEXT I
14002 ? :? "Sorry, your C64 tape has wrong":? "format..."
14003 ? :? "I use only REAL tape format for":? "proper computer..."
14004 FOR I=0 TO 5000:NEXT I
15000 RETURN
17000 RETURN
18000 REM MAKE DEMO
19000 RETURN
20000 REM EXIT
20001 GRAPHICS 2+16
20005 GOTO 20005
21002   ? :NEXT I
25001 DATA ?,?,?,?,
32760 REM ---
pa2023.lst 2.48 kb, liczba pobrań: 3 (od 2023-04-04)
31 Ostatnio edytowany przez mono (2023-04-04 20:46:35)
@Sikor: A czemu wywaliłeś mojego POKa do magnetofonu? ;>
9 TRAP 31782
23 MOTUR=0
100 DIM C$(1)
101 ? CHR$(125):? "┌───┐":? "|* *|":? "└──┘":? "CASSATE OPERATING SYSTEM 1.2.3":? "2023 BC (C) BY PACT"
10000 REM MOTOR ON
10015 GOSUB 31421
11000 RETURN
12000 REM MOTOR OFF
12015 GOSUB 31421
13000 RETURN
15000 RETURN
17000 RETURN
18000 REM MAKE DEMO
19000 RETURN
20000 REM EXIT
20001 GRAPHICS 2+16
20005 GOTO 20005
21000 MOTUR=1:SOUND 0,10,0,1:POKE 54018,52:RESTORE 25000:FOR I=0 TO 2:FOR J=0 TO 4
21002 ? :NEXT I
21003 GOTO 31421
25001 DATA ╲,▄,▄,▄,
25003 DATA ●, , , ,●
32760 REM ---
Jeszcze poprawiłem błąd ze złym naciśnięciem przy motórze.
PA2023.BAS 2.63 kb, nikt jeszcze nie pobierał tego pliku.
PA2023.LST 2.47 kb, nikt jeszcze nie pobierał tego pliku.
32
@mono??? Chyba że w linii 114 był i nie zauważyłem, bo tą tylko wywaliłem. Zaraz dodam, proszę przez 3 minuty nic nie dodawać, bo mam jeszcze uruchomienie programu.
@mono, za dużo przekopiowałem z mojego kodu i nie zauważyłem, czeski niezamierzony błąd. Już powinno być ok. Przepraszam, nie zauważyłem.
9 TRAP 31782
23 MOTUR=0
100 DIM C$(1)
10000 REM MOTOR ON
10015 GOSUB 31421
11000 RETURN
12000 REM MOTOR OFF
12015 GOSUB 31421
13000 RETURN
15000 RETURN
16001 ? "PROGRAM RUNNING...";:C=0
16002 ? "Any key stop it!"
16003 POKE 764,255
16004 IF PEEK(764)<>255 THEN RETURN
16005 POSITION 30,1:? C;:FOR I=0 TO 500+C:NEXT I:C=C+1
16006 IF C>10000 THEN C=0
16007 GOTO 16004
17000 RETURN
18000 REM MAKE DEMO
19000 RETURN
20000 REM EXIT
20001 GRAPHICS 2+16
20005 GOTO 20005
21002   ? :NEXT I
21003 FOR I=1 TO 1000:NEXT I:POKE 54018,52:RETURN
25001 DATA ?,?,?,?,
32760 REM ---
pa2023.lst 2.71 kb, liczba pobrań: 3 (od 2023-04-04)
34 Ostatnio edytowany przez Lizard (2023-04-04 20:44:19)
Tu zaraz będzie kod. Proszę czekać.
35 Ostatnio edytowany przez mono (2023-04-04 20:48:30)
Dobrze się sprawdza Meld do porównywania zmian w tekstach ASCII :)
Edit: @Sikor: Nieee, jak przenosiłeś motór_on do 21000 to zginęło.
36
@mono - poprawiłem, jest w linii 21003
37 Ostatnio edytowany przez mgr_inz_rafal (2023-04-04 20:59:00)
Dodałem obsługę "make demo".
pa2023.bas 3.34 kb, liczba pobrań: 1 (od 2023-04-04)
PA2023.LST 3.12 kb, liczba pobrań: 3 (od 2023-04-04)
38
Takie krótkie pytanie. Linii już napisanych nie można modyfikować? Chciałem rozbudować wyłączenie i dodać coś zamiast pętli 20005.
39 Ostatnio edytowany przez mono (2023-04-04 21:05:55)
W oryginalnym PAC organizowanym przez Sikora nie można było. Ale to często uniemożliwiało optymalizacje, więc rok temu pozwoliłem sobie zmodyfikować reguły. Teraz można usuwać i modyfikować a chodzi tylko o to, żeby przenosząc lub optymalizując uszanować czyjś wkład. Tak więc - nie krępuj się :)
@Sikor: W 21000 masz FOR I=0 TO 3 - za daleko! Powinno być do 2 bo inaczej jest zły dotyk.
40 Ostatnio edytowany przez mgr_inz_rafal (2023-04-04 21:04:18)
Kurde, dobrze, że mamy się nie krępować, bo nie wiedziałem, że kiedyś była zasada, żeby nie ruszać...
Anyway, coś nie działa mi dobrze opcja "A" - sprawdzam, czy to nie ja zepsółem :D
41 Ostatnio edytowany przez Lizard (2023-04-04 21:10:41)
Dodałem sprawdzenie, czy program przed uruchomieniem był załadowany i rozszerzyłem uruchomienie programu.
W tym drugim nawiązałem do pewnej grupy programistów, która umieszcza swoje filmy na Youtubie. Kto wskaże linka do filmu, temu czteropak piwa przy najbliższej okazji.
9 TRAP 31782
23 MOTUR=0:PL=0
100 DIM C$(1)
10000 REM MOTOR ON
10015 GOSUB 31421
11000 RETURN
12000 REM MOTOR OFF
12015 GOSUB 31421
13000 RETURN
14001 ? "LOADING:";:FOR I=0 TO 50:? ".";:FOR J=0 TO 50:SOUND 0,10,10,10:NEXT J:SOUND 0,0,0,0:NEXT I
14002 ? :? "SORRY, YOUR C64 TAPE HAS WRONG":? "FORMAT..."
14003 ? :? "I USE ONLY REAL TAPE FORMAT FOR":? "PROPER COMPUTER..."
14005 PL=1
15000 RETURN
16001 IF PL=0 THEN ? "NO PROGRAM LOADED YET.":? "LOAD SOMETHING BEFORE RUNNING, PLEASE":GOSUB 31421:RETURN
16002 ? "PROGRAM RUNNING...";:C=0
16003 ? "ANY KEY STOP IT!"
16004 POKE 764,255
16005 IF PEEK(764)<>255 THEN 16100
16006 POSITION 30,1:? C;:FOR I=0 TO 500+C:NEXT I:C=C+1
16007 IF C>10000 THEN C=0
16008 GOTO 16005
16100 ? "OBJECT REFERENCE NOT SET TO AN":? "INSTANCE OF AN OBJECT."
16101 ? "WE'RE JUST COLLECTING SOME ERROR":? "INFO, AND THEN WE'LL RESTART FOR YOU."
16102 FOR I=0 TO 100:? "↑(";I;"% COMPLETE)";:FOR C=0 TO RND(0)*200:NEXT C:NEXT I:GOSUB 31421
17000 RETURN
18000 REM MAKE DEMO
18001 GOSUB 31999
19000 RETURN
20000 REM EXIT
20001 GRAPHICS 2+16
20005 GOTO 20005
21002 ? :NEXT I
25001 DATA ?,?,?,?,?
31999 POKE 752,1:POKE 82,0:GRAPHICS 0:? "        *** Sober Chessboard ***"
32000 SETCOLOR 1,255,255:SETCOLOR 2,0,0:FOR MALWINA=1 TO 11
32001 FOR LIC=0 TO 19:? " ?";:NEXT LIC
32002 FOR LIC=0 TO 19:? "? ";:NEXT LIC
32003 NEXT MALWINA:POKE 764,255
32004 ? " ? ? ? ? ? ?>>> wdus cos <<< ? ? ? ? ";:POKE 752,1
32005 IF PEEK(764)=255 THEN 32005
32006 POKE 82,2:POKE 752,0:POKE 764,255:POKE 710,148:POKE 710-1,202:RETURN
32760 REM ---
PA2023.LST 3.48 kb, liczba pobrań: 6 (od 2023-04-04)
42
Podpowiecie czym windowsowym otwieracie ten *.lst do edycji aby entery się normalnie wyświetlały, ale przy zapisie wracało do wersji Atari :)?
43
Ja uruchamiam w emulatorze, przerywam (F7 to jest Break), tam edytuję i zapisuję na dysku pecetowym za pomocą
L."H:PA2023.LST
i/lub
S."H:PA2023.BAS
44 Ostatnio edytowany przez Sikor (2023-04-04 21:16:12)
No to jeszcze sprawdzam włącznie motoru przed wczytaniem, bo to nowoczesny system jest...
9 TRAP 31782
23 MOTUR=0:PL=0
100 DIM C$(1)
10000 REM MOTOR ON
10015 GOSUB 31421
11000 RETURN
12000 REM MOTOR OFF
12015 GOSUB 31421
13000 RETURN
14001 IF MOTUR=0 THEN GOTO 14100
14002 ? "LOADING:";:FOR I=0 TO 50:? ".";:FOR J=0 TO 50:SOUND 0,10,10,10:NEXT J:SOUND 0,0,0,0:NEXT I
14003 ? :? "SORRY, YOUR C64 TAPE HAS WRONG":? "FORMAT..."
14004 ? :? "I USE ONLY REAL TAPE FORMAT FOR":? "PROPER COMPUTER..."
14005 FOR I=0 TO 5000:NEXT I
14006 RETURN
14100 ? "YOU CAN'T LOAD PROCESS WHEN MOTOR":? "IS OFF...";
14101 FOR I=0 TO 200:SOUND 3,10+(I MOD 12),14,8:NEXT I
14102 SOUND 3,0,0,0
15000 RETURN
16004 POKE 764,255
16008 GOTO 16005
16100 ? "}OBJECT REFERENCE NOT SET TO AN":? "INSTANCE OF AN OBJECT."
16102 FOR I=0 TO 100:? "?(";I;"% COMPLETE)";:FOR C=0 TO RND(0)*200:NEXT C:NEXT I:GOSUB 31421
17000 RETURN
18000 REM MAKE DEMO
18001 GOSUB 31999
19000 RETURN
20000 REM EXIT
20001 GRAPHICS 2+16
20005 GOTO 20005
21002   ? :NEXT I
25001 DATA ?,?,?,?,
32001   FOR LIC=0 TO 19:? "  ";:NEXT LIC
32002   FOR LIC=0 TO 19:? "  ";:NEXT LIC
32004 ? "            >>> wdus cos <<<         ";:POKE 752,1
32760 REM ---
pa2023.lst 3.66 kb, liczba pobrań: 3 (od 2023-04-04)
46
prz napisał/a:
W Altirze: Configure System=>devices, ustawiasz Host Devices H:, prawa do zapisu i dalej jak @mono napisał ;)
A Altirrze jest opcja eksploracji dysku, gdzie możesz kliknąć prawym przyciskiem myszy na nazwie pliku i wybrać "Export as text". Podobnie w drugą stronę - "Import as text". Eksploratora wywołujesz (dla dołączonego dysku) poprzez File -> Disk drives -> trójkącik -> Explore disk
48
Sikor, to nie jest Turbobejsik, wywal MOD z linijki 14101 ;-)
A w 21000 chyba trzeba zmienić "FOR I=0 TO 3" na "FOR I=0 TO 2" i będzie git.
49
Sikor napisał/a:
Jak masz SDX o tym H: możesz wypchać sobie buty. :-)
50
mono napisał/a:
Masz rację, zaraz naniosę poprawki, ale potrzebuję 3 minut na załączenie nowego kodu.
