Czołem Atarowcy!
Ponieważ mój dotychczasowy Mad-Pascal to 1.7.1, postanowiłem sobie go odświeżyć. Sciągam najnosze źródełka z gita... łyczek kawki... i make... błąd!
Myślę sobie, ok, wejdziemy do src i skompilujemy z ręki, a tu znowu... zonk! Na dwóch róznych systemach z działającym fpc, to samo (Fedora i Arch Linux):
 % fpc -MDelphi -vh -O3 mp.pas
Hint: Start of reading config file /etc/fpc.cfg
Hint: End of reading config file /etc/fpc.cfg
Free Pascal Compiler version 3.2.2 [2024/05/01] for x86_64
Copyright (c) 1993-2021 by Florian Klaempfl and others
Target OS: Linux for x86-64
Compiling mp.pas
Compiling Common.pas
Compiling CommonTypes.pas
Compiling CompilerTypes.pas
Compiling DataTypes.pas
Compiling FileIO.pas
FileIO.pas(269,15) Warning: An inherited method is hidden by "Assign(const AnsiString);"
FileIO.pas(270,15) Warning: An inherited method is hidden by "Close;"
FileIO.pas(271,15) Warning: An inherited method is hidden by "Erase;"
FileIO.pas(272,14) Warning: An inherited method is hidden by "EOF:Boolean;"
FileIO.pas(273,15) Warning: An inherited method is hidden by "Reset;"
FileIO.pas(274,15) Warning: An inherited method is hidden by "Rewrite;"
generics.collections.pas(1186,20) Note: Call to subroutine "function TEnumerable<System.AnsiString>.GetEnumerator:TEnumerator$1<SYSTEM.AnsiString>;" marked as inline is not inlined
generics.collections.pas(1186,20) Note: Call to subroutine "function TEnumerable<FileIO.TPair<System.AnsiString,System.AnsiString>>.GetEnumerator:TEnumerator$1<FILEIO.TPair$2<SYSTEM.AnsiString,SYSTEM.AnsiString>>;" marked as inline is not inlined
generics.defaults.pas(2634,1) Warning: function result variable of a managed type does not seem to be initialized
generics.dictionaries.inc(191,92) Warning: Constructing a class "TCustomDictionaryEnumerator$4$crc897DEE08" with abstract method "DoMoveNext"
generics.collections.pas(121,14) Hint: Found abstract method: DoMoveNext(<TEnumerator$1$crc6824777A>):Boolean;
generics.dictionaries.inc(191,92) Warning: Constructing a class "TCustomDictionaryEnumerator$4$crc897DEE08" with abstract method "GetCurrent"
generics.dictionariesh.inc(119,14) Hint: Found abstract method: GetCurrent(<TCustomDictionaryEnumerator$4$crc897DEE08>;<var AnsiString>):AnsiString;
generics.dictionariesh.inc(286,33) Hint: Parameter "AFrom" not used
generics.dictionariesh.inc(286,40) Hint: Parameter "ATo" not used
FileIO.pas(199,31) Hint: Parameter "w" not used
FileIO.pas(806,11) Hint: Local variable "c" does not seem to be initialized
generics.collections.pas(144,52) Note: Private type "TCustomPointersEnumerator$2<SYSTEM.AnsiString,FILEIO.TCustomList$1$crc6824777A.PT>.T" never used
generics.collections.pas(144,52) Note: Private type "TCustomPointersEnumerator$2<FILEIO.TPair$2<SYSTEM.AnsiString,SYSTEM.AnsiString>,FILEIO.TCustomList$1$crcE101151F.PT>.T" never used
FileIO.pas(9,16) Hint: Unit "CommonTypes" not used in FileIO
Compiling Tokens.pas
generics.collections.pas(1186,20) Note: Call to subroutine "function TEnumerable<Tokens.TTokenKind>.GetEnumerator:TEnumerator$1<TOKENS.TTokenKind>;" marked as inline is not inlined
generics.collections.pas(1186,20) Note: Call to subroutine "function TEnumerable<Tokens.TPair<System.AnsiString,Tokens.TTokenKind>>.GetEnumerator:TEnumerator$1<TOKENS.TPair$2<SYSTEM.AnsiString,TOKENS.TTokenKind>>;" marked as inline is not inlined
generics.dictionaries.inc(191,92) Warning: Constructing a class "TCustomDictionaryEnumerator$4$crc8EA04C88" with abstract method "DoMoveNext"
generics.collections.pas(121,14) Hint: Found abstract method: DoMoveNext(<TEnumerator$1$crc3746980C>):Boolean;
generics.dictionaries.inc(191,92) Warning: Constructing a class "TCustomDictionaryEnumerator$4$crc8EA04C88" with abstract method "GetCurrent"
generics.dictionariesh.inc(119,14) Hint: Found abstract method: GetCurrent(<TCustomDictionaryEnumerator$4$crc8EA04C88>):<enumeration type>;
generics.dictionaries.inc(191,92) Warning: Constructing a class "TCustomDictionaryEnumerator$4$crc1E1490C8" with abstract method "DoMoveNext"
generics.dictionaries.inc(191,92) Warning: Constructing a class "TCustomDictionaryEnumerator$4$crc1E1490C8" with abstract method "GetCurrent"
generics.dictionariesh.inc(119,14) Hint: Found abstract method: GetCurrent(<TCustomDictionaryEnumerator$4$crc1E1490C8>;<var AnsiString>):AnsiString;
generics.collections.pas(144,52) Note: Private type "TCustomPointersEnumerator$2<SYSTEM.AnsiString,TOKENS.TCustomList$1$crc6824777A.PT>.T" never used
generics.collections.pas(144,52) Note: Private type "TCustomPointersEnumerator$2<TOKENS.TTokenKind,TOKENS.TCustomList$1$crc3746980C.PT>.T" never used
generics.collections.pas(144,52) Note: Private type "TCustomPointersEnumerator$2<TOKENS.TPair$2<SYSTEM.AnsiString,TOKENS.TTokenKind>,TOKENS.TCustomList$1$crc602E2D29.PT>.T" never used
CompilerTypes.pas(872,1) Warning: function result variable of a managed type does not seem to be initialized
CompilerTypes.pas(284,5) Note: Private field "TTypeList.Count" is never used
Compiling Memory.pas
Compiling StringUtilities.pas
StringUtilities.pas(77,3) Note: Local variable "i" is assigned but never used
Compiling Targets.pas
Compiling Messages.pas
Compiling Console.pas
Compiling Utilities.pas
Common.pas(190,20) Hint: Parameter "message" not used
Common.pas(180,32) Hint: Parameter "tokenIndex" not used
Compiling Compiler.pas
Compiling Assembler.pas
Assembler.pas(87,3) Hint: Local const "msg" is not used
Assembler.pas(107,3) Hint: Local const "msg" is not used
Compiling CommonIO.pas
Compiling Debugger.pas
Compiling Parser.pas
Compiling Numbers.pas
Numbers.pas(26,23) Hint: Parameter "valType" not used
Parser.pas(1828,32) Warning: Local variable "identifier" does not seem to be initialized
Parser.pas(1828,3) Warning: Local variable "Block" does not seem to be initialized
Compiling MathEvaluate.pas
Compiling Optimizer.pas
Compiling Optimize.pas
Compiling OptimizeTemporary.pas
Compiling OptimizerTypes.pas
Optimize.pas(461,27) Hint: Parameter "context" not used
opt_STACK_AX_CX.inc(231,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(232,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(233,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(236,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(237,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(239,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(240,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(243,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(244,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(246,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(248,35) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(272,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(273,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(274,9) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(275,9) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(276,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(279,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(280,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(282,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(283,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(286,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(287,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(289,2) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(291,35) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(501,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(502,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(503,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(504,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(505,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(506,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(508,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(509,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(510,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(511,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(512,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(513,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(516,18) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(517,18) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(518,18) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(519,18) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(520,18) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(521,18) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(552,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(553,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(554,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(555,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(556,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(557,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(559,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(560,3) Error: Identifier not found "listing_tmp"
opt_STACK_AX_CX.inc(560,3) Fatal: There were 50 errors compiling module, stopping
Fatal: Compilation aborted
Error: /usr/bin/ppcx64 returned an error exitcode
.. może ktoś to przewalczył, zanim zacznę wyarzać otwarte drzwi? ;-)
-U
Co to jest? Co to jest?.... To przecież... Atari! :)
2 Ostatnio edytowany przez tebe (Wczoraj 19:17:16)
https://github.com/tebe6502/Mad-Pascal/ … tag/v1.7.6
/origin/
p.s.
to co próbowałeś skompilować to wersja JAC!-a
tebe napisał/a:
/origin/
p.s.
Poważnie? Ściągałem przez: gh repo clone tebe6502/Mad-Pascal
Ale ok, pobrałem z powyżeszego linku i...
Tu jest jeszcxe ciekawiej... nie ma ./src, co daje radosne:
$ make
cd src ; make
/bin/sh: linia 1: cd: src: Nie ma takiego pliku ani katalogu
make[1]: Wejście do katalogu '/home/[...]/Mad-Pascal-1.7.6'
cd src ; make
make[2]: Wejście do katalogu '/home/[...]/Mad-Pascal-1.7.6'
cd src ; make
make[3]: Wejście do katalogu '/home/[...]/Mad-Pascal-1.7.6'
cd src ; make
make[4]: Wejście do katalogu '/home/[...]/Mad-Pascal-1.7.6'
cd src ; make
make[5]: Wejście do katalogu '/home/[...]/Mad-Pascal-1.7.6'
cd src ; make
make[6]: Wejście do katalogu '/home/[...]/Mad-Pascal-1.7.6'
... sprawdziłem oba archiwa (*.tar.gz i *.zip):
4 Ostatnio edytowany przez tebe (Wczoraj 21:34:17)
- Releases -> Mad Pascal 1.7.6
- katalog ORIGIN, nie ma katalogu SRC jest ORIGIN
origin.png 10.42 kb, nikt jeszcze nie pobierał tego pliku.
release.png 135.55 kb, nikt jeszcze nie pobierał tego pliku.
