I mentioned this two days ago, so it went by so fast anyway.
No problem at all. :)
AGI-ANTIC i King's Quest na Atari Silnik AGI-ANTIC przenosi klasyczne King's Quest I na małe Atari.
Nowy deasembler dla Atari ST Narzędzie rg-dis ułatwia deasemblowanie kodu dla komputerów Atari wyposażonych w procesory 68x.
MADS 2.1.8 Ukazała się nowa wersja popularnego asemblera MADS z nowymi funkcjami.
atari.area forum » Fabryka - 8bit » IDE Plus w nowej wersji.
Strony Poprzednia 1 … 5 6 7 8 9 Następna
Thanks for reminding me via a comment buried in a thread on a Polish forum I rarely visit.
To już był chyba trzeci raz (co najmniej) w ciągu ostatnich kilku lat, ale dobre i to.
What? The third time a complaint that I had neglected to update the DLT binaries was posted in a Polish forum topic I knew nothing about and cannot read without a translator?
Well - just as well I looked, eventually. :D
Chłopie, nie jestem Twoją niańką, Twój program, Twoje błędy. A temat był poruszany także na AtariAge, pomijając już fakt, że sam obiecałeś to zrobić "w ciągu kilku dni", cztery lata temu:
https://www.atari.org.pl/forum/viewtopi ... 00#p291400
Yeah, and like I say, I forgot and a reminder would have been welcome if you were already going to the trouble of posting here in Polish that I was too lazy or negligent to fix the 'famous' bug. And of course I had fucking fixed it but presumably something happened in real life to divert my attention and I cannot recall receiving a personal reminder since then.
Anyway, DLT folder updated, as I say, purely and solely by virtue of the fact I meandered over here to see if there was anything going on.
There's no point in arguing. A while back, I happened to come across a report about a bug fix in 'fdisk' and I remember it being a bug related to 16 partitions. I didn't know that the fixed version never actually made it into the repository; it wasn't until now that it became clear this is probably the same issue. That was also when Pin found this bug.
I didn't write this with the intention of notifying Flashjazzcat, because I didn't know it was the same bug. I didn't even think he'd read it.
There's no point in getting upset, because this isn't paid work, and no one here signed any contract for this software.
Flashjazzcat, thank you for uploading the fixed version to repository.
My pleasure, and thanks for the wise words.
Odgrzebię temat, żeby nie śmiecić nowym.
Mam pytanie do praktyków, którzy używają IDEplusa z talerzowym dyskiem HDD. Jak przenosicie dane na partycje APT i z powrotem? W przypadku zastosowania karty CF kwestia, przynajmniej w jeną stronę, jest uproszczona - robimy partycję FAT, podpinamy kartę pod PC-ta, wrzucamy dane na tę partycję a potem sobie kopiujemy na APT. W drugą stronę to nie działa z racji braku zapisu w sterowniku FAT ale zawsze to już połowa problemu z głowy. A co z HDD? Jego tak prosto nie da się odpiąć i podłączyć do PC (nie chodzi o samo połączenie bo tania przejściówka na USB załatwia sprawę tylko o konieczność odkręcania/przykręcania w takim przypadku).
Ja korzystam z sio2pc i aspeqt.
W skrócie, jak powyżej: kabelkiem SIO2PC. Konkretnie mam po drugiej stronie tego kabla ustawiony serwer plików dla PC-Linka, u mnie obsługuje to SIO2BSD, ale AspeQt (czy może RespeQt, a może oba) i Fuijinet chyba też to umieją. Do okazjonalnego przesłania paru plików w jedną lub drugą stronę, albo do odświeżenia kopii zapasowej przez COPY /BR, to wystarcza.
Uciążliwe się to może zrobić, kiedy potrzebujesz przekopiować kilkaset MB za jednym zamachem. Wtedy pewnie będziesz wolał odkręcić dysk :)
Też używam SIO2PC i AspeQt. Nie lubię wyciągać karty, wolę poczekać aż dane przepchną się przez kabelek.
potwierdzam, SIO2PC i AspeQt
Jak masz udział SMB, to możesz np. skopiować tam pliki za pomocą PC, podłączyć udział do fujinet i skopiować za pomocą Sparta z urządzenia N:
Kurde, nie zwróciłem uwagi i kupiłem żeński adapter IDE... A myślałem, że sobie dziś wszystko ogarnę
Dzięki, ekipo. Akurat bardzo nie lubię SIO2USB/PC - mam ale nie używam. Jakoś tak... no nie, nie pasuje mi.
Wymyśliłem inny sposób. Wygrzebałem z szuflady starego Side1. Mam na nim partycję FAT. Mogę go wpiąć w złącze carta na ideplusie. Po wczytaniu drivera SIDE.SYS mam dostęp do partycji. I mogę sobie z niego przegrywać rzeczy. Raczej jestem konsumentem treści więc operacja odwrotna jest mało prawdopodobna.
Mam tylko jeden problem - z jakiegoś powodu, jeśli uruchomię komputer z SDX na ideplusie, to po wczytaniu sterownika SIDE.SYS tracę dostęp do dysku IDEPlus i widzę tylko ten w Side1. Natomiast jeśli uruchomię SDX z Side1, to problem nie występuje i widzę obydwa dyski. Nie jest to kwestia literek partycji (zadbałem, żeby nie było konfliktu). Nie rozumiem tego.
A próbowałeś z side2?
Tak. Efekt taki sam - po odpaleniu SDX z ideplusa (v.4.50) i załadowaniu SIDE.SYS tracę kontakt z dyskami APT na ideplusie. Jeśli uruchomię SDX z Side2 (v. 4.49e), wszystkie partycje są poprawnie dostępne. SIDE.SYS w wersji 4.03 w obu przypadkach, fizycznie ten sam plik bo jeśli startuję SDX z Side to komputer się bootuje faktycznie z dysku na ideplusie (nie rozumiem czemu ale tak jest - tu na pewno ktoś wie czemu, jakby "kernel" SDX się ładował z Side ale później filesystem się montował z ideplusa i dalej jechało z niego).
Pewnie masz włączone obie Sparty na raz. Dwa karty na raz w jednym miejscu to nie jest specjalnie dobry pomysł. Trzeba jeden wyłączyć.
Co do reszty, nie mam SIDE, więc nie jestem w stanie sprawdzić. Ale pamiętam, że kiedyś tak kopiowaliśmy pliki na party i to działało ("tak", czyli boot z IDE+, wczytanie SIDE.SYS, dostęp do karty siedzącej w SIDE włożonym do gniazda IDE+)
ok, kupiłem właściwą przejściówkę i niestety. Uruchamiam FDISK i komunikat "No APT devices found". Co może być przyczyną? karta widoczna pod PC
Dobra, działa. Włożyłem, wyjąłem parę razy i działa :)
Dobra. teraz mam error 255 przy próbie inicjalizacji partycji
-- rozwiązano - write protect :)
No właśnie przełączałem, żeby nie było konfliktów (czyli SDX na Side to nie na IDEplus i odwrotnie). Ale tak to się zachowuje. Dlatego napisałem, że tego nie rozumiem. Widać, że SDX jest przełączany bo w obu przypadkach zawartość CAR: jest różna. Jest opcja, że plik SIDE.SYS, który ładuję, jest niekompatybilny z SDX 4.50 i stąd ten zonk... Zobaczę, czy jest update.
[edit]
Toolbox dla 4.50 nie zawiera w ogóle drivera SIDE.SYS/SIDE3.SYS, chociaż changelog twierdzi (cyt.): "SIDE.SYS, SIDE3.SYS, COLLEEN.SYS: updated to make them work again.". Zgłupiałem :-/
[edit]
Zupgrejdowałem tego Side1 do 4.50, wyciągnąłem z niego SIDE.SYS i teraz wszystko działa jak powinno. Chyba mam swój mechanizm transferu danych z PC na HDD w IDE+2.
Założyłem partycję FAT16, external. Żeby działała ze Sparta, potrzebuję sterownika FATFS, prawda?
Prawda :-)
A gdzież go mogę znaleźć ?
Jest w toolboksie.
Wygenerowano w 0.033 sekund, wykonano 62 zapytań
