Olivier Landemarre wypuścił właśnie pełną wersję MyAES 0.98 (wraz z toolbarem Yopla)
AES (Application Environment Services) jest kluczową częścią systemu operacyjnego TOS/GEM dla dużego Atari i klonów.
MyAES jest jednym z dwóch (obok XaAES) rozwijanych zamienników dla Atari AES.
Zmiany w wersji MyAES 0.98:
Fix default windframe (possible crash)
Fix iconified window redraw and clipping issue
Fix shutdown with MyAES now no more crash
Fix possible overload with appl_search()
Fix parameters pass to TOS program
Fix text under icon on taskbar
Fix env pass to application launch
Fix appl_control to hide unhide windows (now taskbar work), Yopla have been fixed
Fix shell launch application as other AES do, now GBE receive CH_EXIT messsage
Fix lost of focus on form_alert for application without menu
Fix possible crash on popup menu
Fix edit field to work with Netsurf
Fix resolution change
appl_control(APC_INFO,..) no return if application is hide or not
Fix issue shel_write() if X11 server was running
Fix default directory for application launch by shel_write()
Fix possible selected icon redraw
More nice disable icon redraw
remove option "flying_menu_fix"
Fix language in English file selector
Fix app_conf.cnf configuration for Taskbar
Possible quit MyAES without doing shutdown
Better multitask when an application do intensive use of VDI
YOPLA :
Better Yopla popup position
Better reactivity when hide to wake up
Add Thing group support with auto.grp support like taskbar, please check readme for use
Interesująca jest droga rozwoju MyAES
MyAES Roadmap up to 1.0:
MyAES have been highly modified this last years around the event kernel 0.96 to 0.98 that need after do a lot of fix, now I not plane to do significative change on it so next versions should be more easy.
Stop any development on MyAES for several month, my spare time will be to work on V4SA but as I need do a lot of test with MyAES I will probably do some change for compatibility
MyAES 0.99 (goal end 2023):
Add new feature for developers to broke some limits of GEM (I think to resource file) and write tool to be able use it - some source code will come with to be able use it on other AES such "Interface" propose it in the past.
Continue to progress in compatibility with less friendly GEM application (work already start with 0.98 version)
Try if possible run in single mode (without preemptive multitask) - this point is for fun if not possible perhaps never come
Clean windows layer code ! (really a mess!)
Continue fix bugs
Try add Wdialog PDLG extension not yet include to MyAES
MyAES 1.0 (Goal end 2024):
Continue work on compatibility with less friendly GEM application
Fix bugs
No new feature, no rewrite anything!
Do a good documentation and a list of application tested with option to use it
