Hi! I heard that sio2pc cable can damage the Pokey chip for Atari, it's true?
ATARI 800XE - u1mb, pokeymax4, ramdisk hell led, ultra video 1.0 XE.
SIO2SD, SIDE3, sio2usb, sio splitter, dragon cart, lantronix mss-100, fujinet (lotharek), rverter, A8PicoCart, a8 pico sio, BT-100, XC12 (T2000), XC12 (SUPER TURBO, TURBO D), both with internal speakers. ATARI 800XE - 2xos (XL OS, Q-MEG), ATARI 800XE stock
my youtube channel
ok.. i found it.. version with rs232 can damage POKEY.. other versions are ok..
my youtube channel
don't even dare to say that you don't want this sio2pc now ;P
its not abobut the chip, its about the ground potential between your pc and atari
if properly grounded, it won't harm your atari
Candle, maybe some diodes could help? I am not an electronic guru, anyone can discover this issue more?
Trafo separujące (albo zabawa z transoptorami - ale to już nie na moje głowe ;) ).
wszystkie trzy strony świata
7 Ostatnio edytowany przez Candle (2009-03-30 16:23:14)
after vidol managed to connect atari and pc between two separate ac phases, and fryed sio part of the pokey, i've designed it around 2002
http://spiflash.org/files/sio2pc-optoisolated.pdf
transoptor, nice.
Chodziło mi o coś w te klimaty:
http://pin.if.uz.zgora.pl/~jsieracki/Optoizolator.html
i burned SiO port.. it doesnt work
my youtube channel
