can i compile BAS to ASM?
i try turbo basic compiler.. it create a FILE.CTB.. but what can i do with that file?
SpartaDOS X 4.51 Wydano aktualizację SpartaDOS X 4.51
Test7800 0.9.0 Pojawiła się wersja 0.9.0 emulatora Test z obsługą nowych kartridży i poprawkami błędów.
6th ATASCII Compo Rusza kolejna edycja konkursu twórczości w trybie tekstowym ATASCII. Prace można nadsyłać do 9 listopada.
THE 800XL Atari zapowiada The 800XL z pełnowymiarową klawiaturą, HDMI, portem na cartridge i 25 grami.
CAS2Audio 1.0.9 Nowa wersja aplikacji odtwarzającej pliki kasetowe na Androidzie z architekturą MVVM.
atari.area forum » Programowanie - 8 bit » BAS to ASM ?
You can merge this file with RUNTIME.EXE (or RUNTIME2.EXE) using, for example LINKER.TXL and you will get the stand-alone executable file. This file you can load from any DOS (without TB).
If you really want ASM source, you can disassembly that executable file. However, in my opinion such action (in case of compiled TB) is little pointless.
in runtime.com i can RUN, LOAD.. but i cant save executable..
not IN runtime, but try to do this with file mentioned by grzybson - linker.txl
it will connect yours program with that runtime.com
i cant found linker.txl in turbobasic.atr.. i have lot versions, compilers, but linker.txl missing
http://atari.pigwa.net/download/TB_xl.zip
Here is ATR image I found some time ago, with LINKER.TXL inside.
when i try "L"OAD, then - error 21 at addr 0. ($226F)
how i can open that file mentioned by linker.txl ?
i make it !! :) thanks.. but 20 line program have 12 kb .. :(
how fastest is it now?
Wygenerowano w 0.026 sekund, wykonano 52 zapytań
