Temat: SIO2IDE z USB i Linux
Czy komus to dziala ?
Podlaczam SIO2IDE z USB to Linuxa no i niby karta i kontroler sa rozpoznawalne ale jakos nie daje rady dobrze zainicjalizowac go jako USB Storage.
usb-storage: device found at 4
[ 2546.591375] usb-storage: waiting for device to settle before scanning
[ 2551.591186] usb-storage: device scan complete
[ 2551.597150] scsi 4:0:0:0: Direct-Access MMSoft SIO2IDE Drive 1.11 PQ: 0 ANSI: 2
[ 2551.602167] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 2551.625167] sd 4:0:0:0: [sdb] 1000945 512-byte logical blocks: (512 MB/488 MiB)
[ 2551.637121] sd 4:0:0:0: [sdb] Test WP failed, assume Write Enabled
[ 2551.637129] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2551.668129] sd 4:0:0:0: [sdb] Test WP failed, assume Write Enabled
[ 2551.668139] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2551.668149] sdb: sdb1
[ 2551.801129] sd 4:0:0:0: [sdb] Test WP failed, assume Write Enabled
[ 2551.801140] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 2551.801150] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 2583.220073] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2614.220075] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2645.220081] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2676.220084] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2707.220079] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2738.220081] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2738.447208] sd 4:0:0:0: [sdb] Unhandled error code
[ 2738.447220] sd 4:0:0:0: [sdb] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
[ 2738.447229] sd 4:0:0:0: [sdb] CDB: Read(10): 28 00 00 0f 45 f0 00 00 01 00
[ 2738.447248] end_request: I/O error, dev sdb, sector 1000944
[ 2738.447261] Buffer I/O error on device sdb, logical block 1000944
[ 2769.220069] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2800.220098] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2831.220081] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2834.817579] npviewer.bin[2731]: segfault at 418 ip 00000000f606aa56 sp 00000000ff8133b8 error 6 in libflashplayer.so[f5e1c000+b04000]
[ 2862.220074] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2893.220077] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2924.220087] usb 2-2: reset full speed USB device using ohci_hcd and address 4
[ 2924.447284] sd 4:0:0:0: [sdb] Unhandled error code
[ 2924.447297] sd 4:0:0:0: [sdb] Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
[ 2924.447306] sd 4:0:0:0: [sdb] CDB: Read(10): 28 00 00 0f 45 f0 00 00 01 00
[ 2924.447327] end_request: I/O error, dev sdb, sector 1000944
[ 2924.447340] Buffer I/O error on device sdb, logical block 1000944
No i zaczyna sie pozniej od nowa i za kazdym razem. Ludzie na roznych forach pisza o podobnych przypadkach z innymi urzadzeniami i mowia ze trzeba by bylo wydluzyc timeout dla usb_storage. Tyle ze nie moge nigdzie znalezdz opcji dla tego modulu. Dla scsi to by bylo cos takiego:
options scsi_mod inq_timeout=20
ale teraz scsi_mod nie jest ladowany nawet jesli wlacza sie emulator scsi dla urzadzen usb.
Czy ktos ma jakies pomysly jak to uruchomic ?
