Koala - masz drugi sygnał z AOL:
Charliechaplin napisał/a:I did not complain but wrote a short note at Abbuc forum - the Unmec demo crashes when in Compyshop mode: ->link<-
But I only tested this in emulator, since I do have a 576k Atari 800XL with Compyshop + Rambo mode available at the same time (therefore no sep. Antic mode available). And no, I do not have a U1MB anymore, I sold both my computers with U1MB to Nir Dary...
Alas, for Atarians that only have Compyshop extension (very common here in Germany), the demo would be unviewable on real Atari and they can only watch it on the emulator, so a ramdisk-picker (setup / configure) would be nice.
Suggestions:
1) The demo could load a pre-set XRAM mode (e.g. Rambo) automatically and only when pressing a key (e.g. Shift) at boot-time the XRAM picker/setup/config. appears and one can choose another mode (e.g. Compyshop, etc.) there that will be used by the demo then.
2) The demo searches for a config. textfile, if none is found the XRAM setup/config. is loaded and when finished saved as a textfile; whenever the textfile is found, this textfile will be used as the pre-set for XRAM. (And if there already is a textfile on the disk that does not match your XRAM, simply delete it and create a new one with the XRAM setup/config.)
Domniemam, że coś poszło nie tak. Może choć wykrylibyście co jest w maszynie, albo dajcie po prostu wybór na zasadzie edycji binarki i możliwości "na chama" wpisania banków. To też wystarczy.
Ostatnio edytowany przez Pin (2017-04-04 21:49:34)
