hi atarians.. new demo Arsantica 0 cant run in my Atari..
https://www.youtube.com/watch?v=gm7GnRw7-Rc
AGI-ANTIC i King's Quest na Atari Silnik AGI-ANTIC przenosi klasyczne King's Quest I na małe Atari.
Nowy deasembler dla Atari ST Narzędzie rg-dis ułatwia deasemblowanie kodu dla komputerów Atari wyposażonych w procesory 68x.
atari.area forum » Scena - 8bit » Arsantica 0 - rough cut - cant run on real HW
How about your RAM expansion standard? Is it RAMBO? Can it be set as 130 XE or Compy Shop?
I can confirm corruption of the title screen, then demo runs fine to the "snake" scene, and finally crashes on green tunnel. That is on my 65XE/800XE with compy shop 512kB. On 800XL with external RAMBO 512kB it is running fine.
According to readme file bundled with demo it should run on stock XL/XE with 64KB of RAM, so the reason must be elsewhere....
Maybe tomorrow I will check with some of my machines, different doses/loaders, etc.
I tried on an XE with 2 different RAM expansion (512KB Rambo style (by AVG) and 256KB Compy Shop (based on schematics from Jer)) and in both cases the graphics hangs after a green tunel effect, though the music keeps playing.
Zamiast wyzywać ludzi od wieśniaków (co nawiasem źle świadczy o poziomie Twojego wychowania)
pobierz paczuszkę z Pigwy i zobaczy co się znajduje w readme....
Nie wiem kto tego readme napisał, ale jest niespójność.
http://ftp.pigwa.net/stuff/parties/prod ... ntica0.zip
64.. tak, czytanie jest dla wiesniakow:
to po coś czytał?
Poza tym to co pokazałeś to jakieś extended version jest.
I did some tests and this demo is so extremely picky that I start to wonder if it was run by author on real hardware.
Stock 130XE + SIO2PC + Respeqt
* built in Respeqt's auto load - FAILURE
* DOS II+/D from D1:, folder with demo as D2: - FAILURE
* XBIOS - yeah, I went that far - FAILURE
65XE with 1MB SIMM Exp set as 1MB Rambo
* SDX 4.49 from hard disk (IDEa) - FAILURE
* SDLOAD from HDD - FAILURE
* XBIOS + SIO2PC + QMEG and stock ROM - again FAILURE
* QMEG's 4.04 internal loader + SIO2PC - HANGS after unlimited bobs. (after watching on altirra, it's before green tunnel)
So now I am watching "Unified" instead.
autor nie chciał żebyście to oglądali, jak widać udało mu się :)
zresztą nie pierwszy raz :)
albo dema zawieszające vbxe do tego stopnia, że kompa trzeba wyłączać by odzyskać obraz, czy idące w maliny po naciśnięciu "ania key" (mam takie klawisze na klawiaturze :P )
czy idące w maliny po naciśnięciu "any key" (mam takie klawisze na klawiaturze :P )
Pin, Ania pisze się z DUŻEJ (WIELKIEJ) litery - to jest klawisz Ani ;)
"Press Ania key" i połowie ludzi wyskakuje w tym momencie 404. ;)
Programmer may want to look over the source code and see what is going on with PORTB (54017,$D301) writes. Compy, Rambo, and U1B all work different.
the beauty of many possibilities ;)
Jeszcze trochę i trzeba będzie HIMEM.SYS załadować :P
może trzeba załadować do pamięci wysokiej Rapidusa i stamtąd emulując napęd SIO przesyłać do pamięci podstawowej :)
Ja mam na to skuteczniejszy patent. Zwolniłem właśnie na dysku 36708 bajtów, oraz 378 bajtów i pomogło
Znalazłem co kiedyś znalazłem i mnie rozbawiło:
x01. Na początku było słowo i w słowie były dwa bajty, i więcej nic nie było.
x02. I oddzielił Bóg jedynkę od zera, i zobaczył, ze to było dobre.
x03. I Bóg powiedział: "Niech będą dane." I stało się.
x04. I Bóg powiedział: "Niech ułożą się dane na swoje właściwe miejsca. I stworzył dyskietki i twarde dyski, i kompaktowe dyski.
x05. I Bóg powiedział: "Niech będą komputery, żeby było gdzie włożyć dyskietki, i twarde dyski, i kompakty." I stworzył komputery i nazwał je hardwarem, i oddzielił software od hardware'u.
x06. Software'u jeszcze nie było, lecz Bóg szybko stworzył programy - duże i małe i powiedział im: "idźcie i rozradzajcie się, i wypełniajcie cala pamięć."
x07. Ale sprzykrzyło się Bogu tworzyć programy samemu i rzekł: "Stworze Programistę według swego podobieństwa i niech on panuje nad komputerami, programami i danymi." I stworzył Bóg Programistę, i umieścił go w Centrum Obliczeniowym, żeby w nim pracował. I przyprowadził on Programistę do drzewa katalogowego i powiedział: "W każdym katalogu możesz uruchamiać programy, tylko z Windows nie korzystaj bo na pewno umrzesz.
x08. I Bóg rzekł: "Nie dobrze Programiście być samotnym, stworzymy mu tego, który będzie się zachwycał dziełem Programisty." I wziął On od Programisty kość, w której nie było mózgu i stworzył To, co będzie zachwycało się dziełem Programisty, i przywiódł To do niego. I nazwał To Użytkownikiem. I siedzieli oni razem pod nagim DOS-em i nie wstydzili się tego.
x09. A Bill był chytrzejszy niż wszystkie dzikie zwierzęta, które uczynił Pan Bóg. I rzekł Bill do Użytkownika: "Czy na prawdę Bóg powiedział, żebyście nie uruchamiali żadnych programów ?" I rzekł Użytkownik: "W każdym katalogu możemy uruchamiać programy, tylko z drzewa Windows nie mozemy abysmy nie umarli" I rzekl Bill Uzytkownikowi: "Jak mozesz mowic o czyms, czego nie sprobowales !" Tego dnia, kiedy uruchomicie program z drzewa katalogowego Windows bedziecie rowni Bogu, bo jednym przyciskiem myszki stworzycie to, czego zapragniecie." I zobaczyl Uzytkownik, ze owoce Windows byly mile dla oczu i godne pozadania, bo jakakolwiek wiedza stala sie od tej chwili juz niepotrzebna, i zainstalowal Windows na swoim komputerze. I powiedzial programiscie, ze to jest dobre, i on tez go zainstalowal.
0a. I zaraz wyruszył programista szukać nowych drajwerow. A Bóg rzekł: "Gdzie idziesz?" A on odpowiedział: "Idę szukać nowych drajwerow, bo nie ma ich w DOS-ie." I wtedy rzekł Bóg: "Kto ci powiedział, ze potrzebujesz drajwerow?. Czy czasem nie uruchomiłeś programów z drzewa katalogowego Windows
0b. Wtedy rzekł Pan Bóg do Billa: "Ponieważ to uczyniłeś, będziesz przeklęty wśród wszelkiego bydła i wszelkiego dzikiego zwierza. I ustanowię nieprzyjaźń miedzy tobą a Użytkownikiem, on będzie cię zawsze przeklinał a ty będziesz mu sprzedawał Windows."
0c. Do Użytkownika zaś Bóg rzekł: "Windows" bardzo rozczaruje cię i spustoszy twoje zasoby, i będziesz musiał używać marnych programów, i nie będziesz mógł się obejść stale bez serwisu programisty."
0d. Programiście zaś rzekł: "Ponieważ usłuchałeś głosu Użytkownika, przeklęte niech będą twoje komputery, gdyż powstanie w nich mnóstwo błędów i wirusów, w pocie oblicza twego będziesz stale poprawiał swoją pracę."
0e. I odprawił ich Pan Bóg ze swego Centrum Obliczeniowego, i zabezpieczył hasłem wejście do niego.
0f. General protection fault.
Może pora na taką konwersję... ;)
Tylko QEMM
a probowal ktos uruchomic to z xBootDos tej wersji z memlo $800 ? powinno siorbać
1. Ściągnąłem dir2atr ze strony Hiasa
2. Ściągnąłem xbootdos ze strony xxl-a - tam jest mowa o memlo $980, gdzie jest wersja z $800?
3. Ściągnąłem demko z pigwy
4. Demko i xbootdos wrzuciłemw jeden folder
5. Odpaliłem: dir2atr -md -B xbootdos.obx arsantica0.atr katalog_z_demem_i_loaderem
I dalej nie działa, any ideas?
PS: Zgłosiłem problem Heavenowi na priw na Messengerze, zobaczymy co z tego wyjdzie.
Wygenerowano w 0.029 sekund, wykonano 66 zapytań
